Inventor General
Active Contributor
Message 1 of 9 (197 Views)
how to place chains in assembly
197 Views, 8 Replies
01-11-2013 06:07 AM
Hi
PLease how do i constrain the 4 chains from the frame to the centre ring.I have managed to get this far but need help continuing.Please see attached files
Cheers
Sam
Active Contributor
Message 2 of 9 (165 Views)
Re: how to place chains in assembly
01-16-2013 05:31 AM in reply to: sam__gleeson
Hi
It is possible for one of you much more experienced users to help me with constraining the chains....the reason i posted here is i thought that the forum was to help out users who need help.I appreciate any time given to help me understand how to do this process as this i know is a generous use of peoples time...I have managed to get this far but need help constraining the chains correctly from the frame to the centre ring
Sam Gleeson
Excel 2013 Edu
Message 3 of 9 (148 Views)
01-16-2013 08:21 AM in reply to: sam__gleeson
You are almost there.
Why didn't you connect the other 3 like the first?
Then connect to 4 points in the ring.
How precise do you need this to be?
You could use only Tangents in the last link in each chain.
I think I would then Ground everything.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Distinguished Contributor
Message 4 of 9 (143 Views)
01-16-2013 08:41 AM in reply to: sam__gleeson
Spoiler
Sam, the only way I have been able to add chains (or wire ropes) to an assembly was by creating a "static" part.  I projected edges and drew the chain from these at  the assembly level.
James Winkler
Product Design Suite Ultimate 2014
Vault Professional 2014
Windows 7 Pro SP1
HP-Z400: 2.67 GHz 12 Gb Ram
Nvidia Quadro FX1800 driver 276.42
Curtis_Waguespack
Message 5 of 9 (135 Views)
01-16-2013 08:47 AM in reply to: sam__gleeson
Hi sam__gleeson,
I didn't take time to look at your files, but here is a link to a model that might help:
A set of links which are constrained to "fall" naturally from Cbliss.com
http://www.cbliss.com/inventor/Parts/Hardware/ChainLinks.zip
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Active Contributor
Message 6 of 9 (134 Views)
01-16-2013 08:48 AM in reply to: sam__gleeson
How precise: i just want it to assemble as if in real life..links not appearing half way through links , ring  etc...etc...
could you show me how you would assemble 1 chain ((only Tangents in the last link in each chain.
I think I would then Ground everything.))....i could then study the result and do the other 3 chains as my learning
Thanks Winks87
Thanks Curtis
Active Contributor
Message 7 of 9 (95 Views)
01-17-2013 06:34 AM in reply to: sam__gleeson
Regards
Sam
Message 8 of 9 (91 Views)
01-17-2013 06:40 AM in reply to: sam__gleeson
All 4 chains need to be constrained before grounding.
I forget - is there a reason you need this as separate parts assembly rather than as one part?
I did a search and found another thread on this topic
http://forums.autodesk.com/t5/Autodesk-Inventor/moveable-links/m-p/3742318#M457248
Active Contributor
Message 9 of 9 (81 Views)
01-17-2013 07:04 AM in reply to: sam__gleeson
No ,can this be done as 1 part...how would you do this as a single part?
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
