Yes. Select them all (using Ctrl-pick, no window), then hitting Tab (or
RMB-->Demote). Constraints of sub-ass'y will be kept, but not to main ass'y.
Afterwards, you can then hit Shift-Tab and they will promote back to main
assembly.
Dave Jacquemotte
Automation Designer
www.autoconcorp.com
"stevensf" wrote in message
news:f186b70.2@WebX.maYIadrTaRb...
> Thanks for the info
> So I guess there is no 'select' 'window' to be able to move more than one at a
time? Since I have a lot of parts not constrained but in the correct orientation
to each other it will be time consuming to move them? What about moving them to
a sub assy, than moving the sub assy? Is there a way to put multiple parts into
a subassy at the same time?
> Fred
