Inventor Forum
how to make the rounds to the center
12 REPLIES 12
Message 1 of 13
167807
407 Views, 12 Replies
sorry for my language
how to round off the visible surfaces inside ?
12 REPLIES 12
Message 2 of 13
Cadmanto
in reply to: 167807
Welcome to the forum,
Are you talking about something other then using the fillet command?
What version are you using?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 13
167807
in reply to: Cadmanto
i use inventor 2014.
I want to get the outline in cross section as in the screenshot.
Message 4 of 13
JDMather
in reply to: 167807
Can you attach your *.ipt file here?
It might be easier to show with actual modeled geometry than to explain in words.
Message 5 of 13
wimann
in reply to: 167807
Looks like you would need to use a loft to create the body of your part. Which means you'd probably have to rebuild from the bottom. My part probably looks nothing like your actual part but I made something and attached it in case it helps.
-Will Mann
Inventor Professional 2020
Vault Professional 2020
AutoCAD Mechanical 2020
Message 6 of 13
167807
in reply to: JDMather
yes
Message 7 of 13
johnsonshiue
in reply to: 167807
Hi! I might be mistaken. The face is already tangent continuous to the adjacent faces. Why do you still need to create fillets?
Software Test Engineer
Message 8 of 13
167807
in reply to: johnsonshiue
you lock photo detali
Message 9 of 13
WHolzwarth
in reply to: 167807
I think, that's your wish. The yellow faces are concave.
Walter
Walter Holzwarth
Message 10 of 13
167807
in reply to: WHolzwarth
yes thank you
how did you do it you ?
Message 11 of 13
WHolzwarth
in reply to: 167807
Look at the feature tree.
But I'm just struggling with another version. I didn't consider the taper from 14.5 to 15.5 in Sketch1
Walter Holzwarth
Message 12 of 13
WHolzwarth
Now the tapered version.
Walter Holzwarth
Message 13 of 13
WHolzwarth
I forgot R15 at the big end. Now added.
Walter Holzwarth
