Inventor General
New Member
jainildesai
Message 1 of 5 (299 Views)
how to make a flat of this part??
299 Views, 4 Replies
11-08-2012 06:17 AM
I Am trying to make a flat of this attached part. The dimensions are correct for the part but I am trying to make it such a way that I can form it using a die with a press break. I tried many different ways but inventor dosent seem to allow me to create a lofted flance using a 3-D profile sketch. any ideas on how o get this part modeled as a sheet metal and have a right flat opattern?
*Pro
jletcher
Message 2 of 5 (245 Views)
Re: how to make a flat of this part??
11-09-2012 10:39 AM in reply to: jainildesai
can you post a picture have not Loaded 2013
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
blair
Message 3 of 5 (232 Views)
11-09-2012 11:51 AM in reply to: jainildesai
You might be able to get this to work using the "Rolled" function within the Sheet-Metal portion of Inventor. You won't be able to get it to work using the 3D Sketch and Sweep.
I really think that this is outside the scope of the Sheet-Metal module in Inventor
IV2015 up1 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
Mark_Wigan
Message 4 of 5 (173 Views)
11-12-2012 05:20 AM in reply to: jainildesai
ie, if the part relies upon the deformation of steel (as usually happens for complex shapes that are not split, formed and re-welded) then it cant be calculated by conventional means.
best regards,
- Mark
PDSU 2014 Windows 7, 64bit. (please consider Kudos or Tag as Solved if your issue is sorted)
M.Peppel
Message 5 of 5 (155 Views)
11-12-2012 08:28 AM in reply to: jainildesai
Hi Jain,
for parts like this you need a special set of tools to unfold them. There are several out there as to name the first three on my mind:
FTI Forming Suite
3DQuickpress
Logopress 3
Regards
Matthias
Nihil Ex Nihilo
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
