hello,
I am using inventor 2012 so I couldn't open inventor 2014 files. I got these files at lynda.com, they're its exercises files. I'm astudent but unfortunately I can't install inventor 2014 because my pc's operating system is windows vista. please help me. I have got a student license.
Solved by mdavis22569. Go to Solution.
thanks a lot for your offer but Is there a another solution? for instance, can i solve my problem by installing a patch? I may not upload the files because they're too much.
Whats stopping you from installing on a Windows vista OS, IV dose not check for the OS version just if your system is 32bit (x86) or 64bit (x64) in the files list. I know it says Windows 7 or later but that's just BS I had IV 2014 running on Vista 32bit until a few months ago, it WILL run but slower than you might be used to.
You will need ALL the Vista updates plus at least version of Dot.NET (.net) plus Windows KB948465 patch at least and possibly direct X 11.
The IV installer will fail and tell you why or what additional routines you need to install before IV 2104 will run
Hi, thanks for advice. I download inventor 2014 at http://www.autodesk.com/education/free-software/inventor-professional adress. there isn't inventor 2014's browser download at this website. while I was installing inventor 2014, I saw operating system unsupported textbox. I installed directx 11 as you say and I have already installed windows vista service pack 2.
screenshot:
I downloaded inventor 2014 with bittorrent but I while I was installing it, I saw the same textbox. unfortunately this solution didn't work too. however thanks for your suggestions.
system requirements: http://autode.sk/1lgpfbq
