Dear sir / madam , we have Inventor prof 2012 lisc copy ,now we recd 2013 upgrade copy , as per discusswith local service provider of Autodesk need to uninstall whole 2012 and reload fresh 2013. i copied contenet center folder on other location and reload fresh Inventor 2013.when i installed it it is obserbed that content center libraries don't have standards which contents in Inventor 2012. To open our old projects we need this standards, kindly suggest the procedure to import this content center libraries from 2012 to 2013.
R S Modi
Thank u
Open the Project: Select the lower RH icon (drop-down box),
This will then open the window to migrate your old CC files. You should have them copied to the correct folder before. If you click on the link at the top of the list it will open the correct folder to place your CC files.
