Hello All,
I have built a CAD geometry on Inventor, and I need to do a set drawing, with a ballon for each part of the object. the problem is, as I have build the model as only one, when I try to do a ballon, it selects the entire model. Is there any way that It is possible to do a custom selection of the lines that I want to assign a specific number on the ballon? Or how can I solve this problem?? I want to do a drawing like on the picture i´m attaching.
regards,
hugolopessilva
Hi , Thanks for the reply!!
I will do it in separated files and them assemble it. How can I do it?? After I create all parts, shall I create a new assembly and them open each individual part???
thanks,
Hugolopessilva
@hugolopessilva wrote:
Hello All,
I have built a CAD geometry on Inventor.....I want to do a drawing like on the picture i´m attaching.
regards,
hugolopessilva
Can you attach the *.ipt file here?
Or create a simple dummy file that would exhibit the same behavior.
The CADWhisperer YouTube Channel
Actually, I am unable to disclose the geometry. I´m sorry.
That is why my suggestion was to create a "dummy" file that doesn't include any proprietary information.
The process is pretty simple.
Create multi-body file.
Push out the parts and assembly.
Document the drawing.
Of course there is a bit more to it, but without a file do demonstrate.....
Hello all,
I´m facing a problem when i try to assemble my parts. I have a square beam (ex_2_2.ipt), and I want to constrain a plate on the edge (ex_2.ipt), as shown on (ex_2_3.ipt). How can I do that from two separated parts?? the rectangular beam, and the plate?? the .ipt files are attached.
regards,
HugoLopesSilva
Start a new *.iam (assembly) file.
Click Place and select the ex_2.ipt file.
Click Place again and select the ex_2_2.ipt file.
Save and attach the *.iam file here (we'll work through this step-by-step).
Thanks for the reply,
I have already opened the two files in a new assembly file .iam. I´m attaching the .iam file. Please guide me through the next steps.
Thanks Mr. Mather,
Hugo
1. Add a Mate constraint between a long face of the bar and large face of the plate.
2. Add a Mate-Flush constraint between an end face of the bar and end (edge) face of the plate.
3. Add a Mate-Flush constraint between perpendicualr face adjacent to 1. above on the bar and long edge face of the plate.
Post back your assembly if you have any trouble and I will illustrate with pictures.
Post back with next problem for next step.
