Inventor General
Distinguished Contributor
James__S
Message 1 of 17 (402 Views)
how to cut out worm case
402 Views, 16 Replies
01-27-2014 04:55 AM
Hello
Using Inventor 2013/2014 .. how do i cut out the worm case so that the worm can rotate correctly inside..it will be part of a pump (mono)
Cheers
James
James__S
Message 2 of 17 (349 Views)
Re: how to cut out worm case
01-28-2014 08:28 AM in reply to: James__S
Hi
Still looking for advice on how best to approach the cut.What tools should i use and i shall attempt myself to make the cut.I am new to Inventor so need some guidance on how best to create the cut to suit the worm
Best Regards
James
*Expert Elite*
JDMather
Message 3 of 17 (345 Views)
01-28-2014 08:40 AM in reply to: James__S
You are going to have to supply more information.
Pictures of actual parts?
Url to similar parts?
First thing I noticed is that your circle sketch is not perpendicular to the Sweep path, therefore the twisted "wire" is not round.  (slightly oval)
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
James__S
Message 4 of 17 (328 Views)
01-28-2014 10:33 AM in reply to: JDMather
Hope these pictures can help
*Expert Elite*
dan_inv09
Message 5 of 17 (315 Views)
01-28-2014 02:43 PM in reply to: JDMather
Pictures like these?
James__S
Message 6 of 17 (289 Views)
01-29-2014 05:02 AM in reply to: dan_inv09
Thanks.Those pictures are exactly what i am wanting to replicate
Hopefully some help on how to create would be appreciated
Thank you
James__S
Message 7 of 17 (268 Views)
01-29-2014 10:18 AM in reply to: James__S
Thoughts please.It looks like either the 100% or 200%.
Best regards
James
*Expert Elite*
JDMather
Message 8 of 17 (264 Views)
01-29-2014 10:33 AM in reply to: James__S
This is not going to be an easy problem.
It would be best if you made some attempts and attach them here for pointers.
*Expert Elite*
dan_inv09
Message 9 of 17 (256 Views)
01-29-2014 10:57 AM in reply to: JDMather
http://www.youtube.com/watch?v=F3-rpy8qrOA&list=PLWbKJby--ZPSU6srfO18AQns_Am-5cETi
"The progressive cavity pump consists of a helical rotor and a twin helix, twice the wavelength and double the diameter helical hole in a rubber stator."
from http://en.wikipedia.org/wiki/Progressive_cavity_pump
it looks like it might be as simple as
James__S
Message 10 of 17 (230 Views)
01-30-2014 06:11 AM in reply to: James__S
Thanks for the part.It looks very much like the stator.
Would the worm also be made using the Coil tool?
Cheers
James
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
