Inventor General
Valued Contributor
linuskotte
Message 1 of 3 (734 Views)
how to convert the weldment assembly back to regular assembly template
734 Views, 2 Replies
06-06-2012 07:26 PM
Hi all
I am using INV 2012 and I wan to to know a trick how to convert the weldment assembly back to regular assembly template.
any macros are there please suggest me
Thans for advance.
linus kotte
*Expert Elite*
Curtis_Waguespack
Message 2 of 3 (732 Views)
Re: how to convert the weldment assembly back to regular assembly template
06-06-2012 07:34 PM in reply to: linuskotte
Hi linuskotte,
You can place the weldment in a new assembly, and promote (drag and drop in the browser) all of the components up to the top level and then delete the weldment assembly. Then simply save the new assembly as the correct part number to replace the original assembly.
But unfortunatly there is no button or option to turn a weldment assembly back to regular assembly.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
New Member
aaniaa13
Message 3 of 3 (149 Views)
04-25-2014 12:55 AM in reply to: Curtis_Waguespack
I found that I can just copy parts from weldment to new assembly. By copying all relations are converted too.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
