Inventor Forum
how to change default units to metric for inventor2013
5 REPLIES 5
101322 Views, 5 Replies
how to change default units to metric for inventor2013? Now I have them set as imperial.
thanks and regards
Jis
5 REPLIES 5
WHolzwarth
You can select units by using special templates, whe setting up a new file.
By default here with a German version, the template is called Norm.ipt and is in millimeters. And there are subfolders, too, for English or Metric setup.
Walter
Walter Holzwarth
SBix26
I'm not sure if you're asking about changing a single file, or about changing templates?
To change a single existing part or assembly file, open Tools tab > Document Settings > Units tab and change units as you please.  To change a single drawing, you will probably need to create some metric styles.
To change to metric templates as installed, Application Options > File > Configure Default Template... button.
in reply to: SBix26
Thank you very much!  I had this same question and your answer was so simple and precise.  Thanks for the support.
So I changed the part files properties to use Metric. Thats fine. It's still displaying with a +90deg pitch (i think I used the YZ plane (Inventor) which is the RIGHT plane, not the FRONT.
The model is still displayed at a fraction of the part size.
JDMather
Attach your file here.
If you modeled using magnitude with incorrect units - changing the units isn't going fix the part.
ex, 1 inch become 25.4 mm not 1 mm
