Inventor Forum
how to change background colour of drawing sheet
5 REPLIES 5
indalkar.dattatray
45616 Views, 5 Replies
Dear All,
I have little question that, is it possible to change background colour of drawing sheet in inventor?
I have to change background colour white to black ( as in autocad) .
If it is possible pls where is setting in how to do it?
Thanks and regards,
Datta Indalkar
With Warm Regards,
Datta Indalkar.
5 REPLIES 5
sam_m
in reply to: indalkar.dattatray
You can change the sheet colour by: Tools ribbon -> Document settings -> Sheet tab and the "sheet" button
but, I don't know how well it will work with a black sheet, as all the lines/dims/views/etc will be black on a black background.  You'll need to change all your layer-colours (manage ribbon -> Styles Editor -> Layers) to white to make them visible, but then when you print anything it will be trying to print white lines on white paper...
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
The sheet Background colour is set in:
Tools > Application options > Colors
The colour of the drawing back ground depends on the style you are using.
You can create your own styles, see this post:
http://opendesignproject.org/2010/09/02/creating-a-new-application-color-scheme-in-autodesk-inventor...
Autodesk Industry Marketing Manager UK D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
indalkar.dattatray
in reply to: sam_m
Dear Sam_m;
Thanks for your Answer. I got that setting.
But you are right it is not going to work better as white sheet.
Thanks for your advise.
Have great day.
Thanks and Regards,
Datta Indalkar
With Warm Regards,
Datta Indalkar.
rwhiteKTJ84
in reply to: PaulMunford
I found it in Tools / Document settings / Sheet tab..... change color to white
jrohit1110
in reply to: rwhiteKTJ84
Can we also export a dark drawing?
Eg:
Warm Regards,
Rohit Kumar J
