Inventor General
Active Contributor
indalkar.dattatray
Message 1 of 4 (8,181 Views)
how to change background colour of drawing sheet
8181 Views, 3 Replies
06-10-2012 11:37 PM
Dear All,
I have little question that, is it possible to change background colour of drawing sheet in inventor?
I have to change background colour white to black ( as in autocad) .
If it is possible pls where is setting in how to do it?
Thanks and regards,
Datta Indalkar
With Warm Regards,
Datta Indalkar.
sam_m
Message 2 of 4 (8,169 Views)
Re: how to change background colour of drawing sheet
06-11-2012 12:55 AM in reply to: indalkar.dattatray
You can change the sheet colour by: Tools ribbon -> Document settings -> Sheet tab and the "sheet" button
but, I don't know how well it will work with a black sheet, as all the lines/dims/views/etc will be black on a black background.  You'll need to change all your layer-colours (manage ribbon -> Styles Editor -> Layers) to white to make them visible, but then when you print anything it will be trying to print white lines on white paper...
Please mark this response as "Accept as Solution" if it answers your question...
but please understand that the solution may not be the answer you're wanting to hear...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love :smileyvery-happy:
Lithium - helping nntp users with mania, depression and headaches
PaulMunford
Message 3 of 4 (8,162 Views)
06-11-2012 03:34 AM in reply to: indalkar.dattatray
The sheet Background colour is set in:
Tools > Application options > Colors
The colour of the drawing back ground depends on the style you are using.
You can create your own styles, see this post:
http://opendesignproject.org/2010/09/02/creating-a-new-application-color-scheme-in-autodesk-inventor...
The CAD Setter Out Blog @CadSetterOut
Inventor Surfacing | AutoCAD | CAD Standards
Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
Active Contributor
indalkar.dattatray
Message 4 of 4 (8,130 Views)
06-11-2012 09:04 PM in reply to: sam_m
Dear Sam_m;
Thanks for your Answer. I got that setting.
But you are right it is not going to work better as white sheet.
Thanks for your advise.
Have great day.
Thanks and Regards,
Datta Indalkar
With Warm Regards,
Datta Indalkar.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
