Inventor Forum
how can i hide constraint tooltips in inventor 2012
13 REPLIES 13
Message 1 of 14
paula
617 Views, 13 Replies
one thing that is driving me nuts is when picking features for constraints, this tooltip or hud pops up and screws my selected choice up...can i turn it off and if so, where?
13 REPLIES 13
Message 2 of 14
johnsonshiue
in reply to: paula
Hi! I am a bit confused here. Could you tell me what you meant by "picking features for constraints"? Is this in assembly environment or in part environment?
Thanks!
Software Test Engineer
Message 3 of 14
mcgyvr
in reply to: johnsonshiue
I think they are talking about the select other dialog. I haven't loaded 2012 yet but you should be able to change the delay so that it takes longer for that dialog to be triggered. In 2011 it was tools..application options..general tab..and change the select other delay.
Message 4 of 14
paula
in reply to: mcgyvr
actually there is a delay, but on the first constraint...if i hover over my part, after 1 sec, another little transparent popup appears with a list of features to chose from
i.e.
1. FACE NORMAL
2.  AXIS
3. FACE NORMAL
4. FACE NORMAL
5. CENTER POINT
etc.
But i have turned off all tooltips and it still shows up.
I cant do a print screen of it, cause it disappears at time of capture.
Message 5 of 14
Dennis_Jeffrey
in reply to: paula
That is the new Select Other box
____________________________________________________________
Dennis Jeffrey, Author and Manufacturing Trainer, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert
Autodesk Silver Manufacturing Partner
Subscribe to the free digital "The Creative Inventor Magazine" now available at: http://teknigroup....
XP64 SP2, GeForce 9800GT-1GB, Driver: 6.14.12.7061, 8GB Ram, AMD Athlon II 3.2 Ghz
Laptop: Win7-64 Pro, 4GB, ATI Graphics on board, 2012 Ultimate, IV2011 or 2010 Pro, all SP's
Message 6 of 14
paula
in reply to: Dennis_Jeffrey
that stinks....thanks dennis
Message 7 of 14
JDMather
in reply to: paula
You can change the delay so that it doesn't pop up so quickly.
Message 8 of 14
paula
in reply to: JDMather
i have all the tooltips shutoff
Message 9 of 14
mcgyvr
in reply to: paula
Its NOT a tooltip.
You can set the delay to 10 seconds or whatever and you won't see it unless you hover over somethign for 10 seconds or more..
Message 10 of 14
paula
in reply to: mcgyvr
ok, you dont have to yell
and where may i do that at?
Message 11 of 14
JDMather
in reply to: paula
Just to the right of where you turned off the tooltips.
Tools>Application Options>General tab
Message 12 of 14
paula
ok thanks
Message 13 of 14
paula
in reply to: paula
unfortunately i still need it to select other so back to square one lol
Message 14 of 14
JDMather
in reply to: paula
Just Right Mouse Button whenever you need to Select Other
- or find a delay that is long enough but not too long for your normal workflow.
