Inventor Forum
holes in cylinder
9 REPLIES 9
Message 1 of 10
18083 Views, 9 Replies
holes in cylinder
I'm very new at this so I'm sorry if this is dumb. I created a cylinder with a hole through the center and need to add holes through the face into the center hole and I can't figure out how. Any help would be greatly appreciated. Thanks in advance.
Tags (1)
9 REPLIES 9
Message 2 of 10
JDMather
Create new workplane.
Select one of the origin planes or axis.
Select side of cylinder.
Now you have a plane on which to Sketch a Hole Center Point.
Message 3 of 10
in reply to: JDMather
Sorry if I seem a bit inept, but I can't seem to do this at all. I have a 1.5" dia Cylinder and need 4 holes in the side. The directions you gave aren't making much sense to me. I have tried to do the things you suggested but so far nothing. I am using Inventor 2013.
Message 4 of 10
JDMather
See image below
Message 5 of 10
Hi, I New to do 3 holes in a cilinder, the angle between the axis hole is 60 degrees,, I made I hole in a plane, but  I dont know how to  do the other 2 holes, how can I made it? I m attaching a autocad draw of what i need to do .
Message 6 of 10
JDMather
Create the first hole and then do a Circular Pattern.
Attach your ipt file here if you can't figure it out.
Message 7 of 10
I am attaching the File, I will try to use the circular pattern, im new in autodesk inventor so i will try how to use that option.
Message 8 of 10
I really dont know how to use the circular patterm, Could u help me, im sorry im very new in autodesk inventor
Message 9 of 10
JDMather
Click Circular Pattern tool.
Click on the Hole.
In the Circular Pattern dialog box select the Selection tool for Axis and select the side of the cylinder.
Enter 3 instances and click OK.
BTW, your sketches are not constrained and you are doing too much work.
I recommend you go through these
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
http://inventortrenches.blogspot.com/p/inventor-tutorials.html
http://wikihelp.autodesk.com/enu?adskContextId=HELP_TUTORIALS&language=ENU&release=2014&product=Inve...
Message 10 of 10
ThanKs i already did the 3 holes, thanks, I will check the info you have sent me. thanks
