Inventor Forum
holes around the oustside of a plate?
6 REPLIES 6
173 Views, 6 Replies
Is there an easy way to array holes around the outside of a rectangular
plate.
What I have is 5ft x 10ft plate. I need 30 holes across the ends and 60 down
the sides.
Its not that I can't get the holes in. But it seem to take longer than it
should, because you can't array an arrayed hole.
What I really want is the regular array but leave out the center holes.
Lester Martin
Reist Welding Ltd.
Toll Free: 1-888-565-5587
pH.: 519-669-1501
Fax: 519-669-3021
E-mail: lester@reist.on.ca
6 REPLIES 6
you can do the full array and supporess the inside features that you dont
want.
see CF for an example.
Matt
"Lester Martin" wrote in message
news:BACDA20CD0AC147D3AAF9C1F1B8B4B5E@in.WebX.maYIadrTaRb...
> plate.
down
> the sides.
> Lester Martin
> Reist Welding Ltd.
> pH.: 519-669-1501
> Fax: 519-669-3021
OK I see what you did but question
#1 how do I select 1600 holes quickly?
#2 Arraying 1800 hole makes a very heavy drawing. does it get lighter when
you suppress the 1600 holes?
"Matt Stocking" wrote in message
news:BDA0A24934BFC3EFFDED2EEB552F203D@in.WebX.maYIadrTaRb...
> want.
> Matt
> > plate.
> down
> > the sides.
it
> > Lester Martin
> > Reist Welding Ltd.
> > pH.: 519-669-1501
> > Fax: 519-669-3021
Les
FYI R6 allows you to array features along a path.
Very easy to do with offset line
- drew
Drew Fulford B.A.Sc. Systems Engineer
Solid Caddgroup Inc. Burlington, Ontario
Tel: (905)331-9670, Fax: (905)331-7280
Corporate: http://www.solidcadcam.com/
Member of the Autodesk Discussion Forum Moderator Program
Visit my MCAD website @ http://www.mymcad.com/
> plate.
down
> the sides.
> Lester Martin
> Reist Welding Ltd.
> pH.: 519-669-1501
> Fax: 519-669-3021
I guess there is no quick way to select that many holes 🙂
Couldn't you just put 4 holes and have 4 arrays? You could put 1 hole in
each corner.
Matt
news:DE974A184D571A566CF38314DCAD358D@in.WebX.maYIadrTaRb...
dont
> > want.
> > Matt
rectangular
> > > plate.
60
> > down
> > > the sides.
> it
holes.
> > > Lester Martin
> > > Reist Welding Ltd.
> > > pH.: 519-669-1501
> > > Fax: 519-669-3021
Yep
That's what I do. But thetas why I think there should be a faster way.
I guess in Inventor 6 it does it the way I want it to.
news:80DC7AD50C6F4E763F345098E286C15D@in.WebX.maYIadrTaRb...
> each corner.
> Matt
when
> dont
> > > want.
> > > Matt
> rectangular
> > > > plate.
> 60
> > > down
> > > > the sides.
than
> > it
> holes.
> > > > Lester Martin
> > > > Reist Welding Ltd.
> > > > pH.: 519-669-1501
> > > > Fax: 519-669-3021
Do you get to have different spacing (or space to fit) for each side? in one
step?
K
"Drew Fulford" wrote in message
news:262FE4855D0E8B2F8759741AC605A44C@in.WebX.maYIadrTaRb...
> Les
> - drew
> > plate.
> down
> > the sides.
it
> > Lester Martin
> > Reist Welding Ltd.
> > pH.: 519-669-1501
> > Fax: 519-669-3021
