Hole note does not work when holes are edited with thicken/offset. It will write the original diamter, not the new one. Just to let you guys know.
The Hole Note and Hole Table only read data created with the Hole Feature tool. If it's changed with the Thicken or using the Extrude Feature, these actions will not change the basic Hole meta-data. This is as designed.
