Inventor General
Valued Contributor
trenthoskings
Message 1 of 6 (191 Views)
hinge
191 Views, 5 Replies
11-16-2012 04:59 AM
I`m stuck at this point.I have 2 brackets which they both need cutting so as to create a hinge.The part is sheet metal formed.How does one make the cuts so as to create the hinge and also how can i flatten these 2 pieces please?
Trent
IV-2013
Valued Mentor
japike
Message 2 of 6 (185 Views)
Re: hinge
11-16-2012 05:18 AM in reply to: trenthoskings
I'm not sure how you need these cut but I attached one possibility. Look at the browser to see how it was done. As to the flat, pick a face a click on "Create Flat Pattern".
Peace,
Jeff
Inventor 2013
Valued Contributor
trenthoskings
Message 3 of 6 (163 Views)
Re: hinge
11-16-2012 07:03 AM in reply to: japike
Thanks Jeff
I also did a bit of a search and there is a cut across bend??..not sure how that works but i will try and find more info...thanks for your solution
Trent
Valued Mentor
japike
Message 4 of 6 (160 Views)
Re: hinge
11-16-2012 07:07 AM in reply to: trenthoskings
Can you give a better discription of what you are trying to accomplish?
Peace,
Jeff
Inventor 2013
Valued Contributor
trenthoskings
Message 5 of 6 (154 Views)
Re: hinge
11-16-2012 07:17 AM in reply to: japike
OK...1 bracket will have the middle third cut out and the other hinge will have the 2 outside cut off leaving just a third in the middle....Thank you
Valued Mentor
japike
Message 6 of 6 (144 Views)
Re: hinge
11-16-2012 07:50 AM in reply to: trenthoskings
I think you'll need two different brackets. See attached.
Peace,
Jeff
Inventor 2013
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
