Hi
I have made a 3d-model of an iphone for a school, but wheen I added a picture to the front side and finished the sketch there where yellow lines all around. What i wonder is if there is any way to hide just the lines for that specific sketch, because when i tried to hide the sketch itself the picture got hidden to...
Solved by cwhetten. Go to Solution.
Solved by Curtis_Waguespack. Go to Solution.
Hi edde27,
You can use the Decal tool, to convert the sketch to a feature and show the graphic image still.
You can visit these links for more information on the Decal tool:
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-B46E034E-C730-4B26-A452-3C50E6640216
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-FB0EE9C8-5A9C-41E0-AFE7-CAAE7418EA7A
I hope this helps.
Curtis
Hi and welcome to the forum!
Try using the Decal command:
Cameron Whetten
Inventor 2014
Please click "Accept as Solution" if this response answers your question.
Thanks for answering my question so quickly!
Didn't know that tool even existed as it was in that little dropdown menu 🙂
