Hello. Using ISO.idw template I created into a sheet a Sketch which contains a hatch. Now I want to delete that hatch and I don't find anywhere how to delete it.
The second problem is this: I want to create in multiple sheets the same drawing but with small differences. How to copy a drawing from a sheet to another sheet. I press right click on the first sheet and i press Copy but there's no Paste button.
Solved by inchul.lee. Go to Solution.
Hi nicu_bogd,
If you want to remove a hatch,
You can't copy sheets within a drawing. Please follow these steps,
You can still copy Views within a drawing.
I hope the above answers your question.
Thanks.
