Inventor Forum
Welcome to Autodeskā€™s Inventor Forums. Share your knowledge, ask questions, and explore popular Inventor topics.
Showing results forĀ
Did you mean:Ā
gtx 660 anti-alias
46 REPLIES 46
Message 1 of 47
rmerlob
3808 Views, 46 Replies
gtx 660 anti-alias
So, I got a new GTX 660 rig and antialias looks worse on my 1920x1080 monitor than with my gt220m laptop, really looks like a bug, seems to try and anti-alias but when i move the model it gets jagged like in the picture, some artifacts too.
I know these cards arenĀ“t supported but come on if looks okay on a gt220m it should look okay in this one, by the way I got a quadro 600 at work and looks exactly the same as the gt220m though it is faster.
Any suggestions?
RM
46 REPLIES 46
Message 2 of 47
rmerlob
in reply to: rmerlob
For clarity, this is how I would expect it to look.
Message 3 of 47
blair
Check the Inventor Application options to see that you are using either Quality or Performance in the Hardware tab. I also assume that you are on the latest Nvidia drivers that are Microsoft certified.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi Ī”Ī¤Ī§
Message 4 of 47
rmerlob
Thanks for your answer, I am on quality (I dont think theres antialias on the other modes), I installed the latest drivers for my card form the geforce site, are those not microsoft certified?
Message 5 of 47
DarrenP
it would say whql on the  nvidia driver website
DarrenP
Message 6 of 47
rmerlob
Drivers are 310.90 - WHQL....... could anyone confirm this drivers/card works ok on other computer?
Message 7 of 47
blair
Works on my system, hardware set to Quality and view to either shaded with and without edges
Message 8 of 47
rmerlob
IĀ“m at a loss here, could you post a jpg of how things look on your system?
Message 9 of 47
blair
Hardware set to Quality:
Capture1 Shaded
Capture2 Shaded with Edges
Message 10 of 47
rmerlob
in reply to: blair
Thanks Blair, that looks great, have no idea what coul be up on my system, if I set to software render my core I7 seems to anti-alias it just fine, slower than a graphics card but no artifacts and super smooth edges.
Maybe someone else can pitch in, mb someone from autodesk.
Your graphics card is a much better model than mine from a previous series, how much difference between architectures you  think there is?
Message 11 of 47
blair
Not really sure, I am just starting to assemble a new machine with the GTX690 in it. I generally work in Performance mode with Shaded (no edges). though.
Message 12 of 47
rmerlob
Let me know how the 690 turns out, I used to work in performance, I find quality much easier on the eyes though after using it for a while its hard to go back everything looks so jagged.
Message 13 of 47
blair
Will do, I am slightly delayed on the build, I had to make a change on the CPU cooler. The model of EVGA mother board has moved the memory "chips" in closer to both sides of the CPU and with the height of the cooler fins on the chips I am unable to seat my desired CPU cooler. I am waiting for the new cooler to arrive to power up the unit.
Message 14 of 47
rmerlob
in reply to: blair
Any news on this, anyone?
Message 15 of 47
Vlad.Makarov
I upgraded my GTX 570 to a 670 & the same problems manifest. No problems on the 570 though.
______________
Inventor Pro 2012
Vault Pro 2012
Message 16 of 47
blair
in reply to: blair
Quality setting with "Shaded Edge": System specs are below:
Message 17 of 47
Vlad.Makarov
in reply to: blair
Maybe I need to get my eyes checked, but that looks pretty jagged.
______________
Inventor Pro 2012
Vault Pro 2012
Message 18 of 47
blair
in reply to: Vlad.Makarov
The attachment might give a better picture. I don't normally use shaded with edge
Message 19 of 47
swhite
under application Options on the Display Tab make sure display quality is set to at least smooth.
Steven White
Lee C. Moore, Inc.
www.lcm-wci.com
Inventor 2011
Intel Dual Xeon E31225 @ 3.1 GHz CPU
16 GB RAM
NVIDIA Quadro 600 GPU
Windows 7 - 64 Bit
Message 20 of 47
Vlad.Makarov
in reply to: blair
Eh, the more I look at that the more jaggies I see. Maybe I've crossed over into hypercritical territory.
______________
Inventor Pro 2012
Vault Pro 2012
