Sean, Dennis "Ghost Busters"
Thanks for the tip that worked perfectly. No more ghost's
"Dennis Jeffrey" wrote in message
news:3DF6CF70.9C8927E2@cadassociates.com...
> Try this in Win2K and XP Pro - Turn off pointer Shadow (Control Panel -
Mouse),
> Turn off Use Transition Effects (Control Panel-Display) These settings
will
> affect all systems regardless of card & driver.
> Dennis
> Josh Beissel wrote:
> > I have a "ghost box" that stays on screen after opening a tool like
measure
> > which has a drop down. If I pick any option from the drop down, then I
get
> > a "ghost box". It will go away as soon as I pan or zoom, but it is
annoying.
> > Is it my graphics card setting? I'm not sure how it should be set up for
the
> > best performance with IV6.
> > Any help or suggestions would be great.
> > Thanks, Josh
> > The graphics driver has not been certified.
> > The graphics driver ID is NVIDIA Corporation\Quadro4 750
XGL/AGP/SSE\1.4.0
> > Graphics driver file nv4_disp.dll is version 6.13.10.4109
> > Using Full optimization (this is the recommended setting)
> > SwapType = 2
> > Workarounds = 0x10080000
> > Workarounds2 = 0x00000040
> > The display is using 32-bit color
> > HW Library Version = Win2K - $Revision: #3 $
> > HW Library Date = $DateTime: 2002/11/11 13:09:54 $
> > Options = 0
> > Warning Options = 8
> > Settings for optimized and conservative:
> > SwapType: 2, 3
> > Workarounds: 0x10080000, 0x10080000
> > Workarounds2: 0x00000040, 0x00000040
> > Text Options: 0x00000000, 0x00000000
> > OpenGL Version: 14, 14
> > Recommended Optimization Level: 2
> > Texture Font Precision: 32
> > Stroke Font Precision: 0.001000
> > Driver Rating: 0
> > Using OpenGL 1.1
> > swap behavior: swapCopy(1 or 2)
> > OpenGL errors: None.
> Dennis Jeffrey
> CAD Associates - Fort Wayne
> Autodesk University Instructor
> Autodesk ASC
> (260-432-9695 x 221
