Does anyone know whether inventor supports the geometric tolerancing/symbols to bs 308 or ansi version such as concentricity,flatness etc etc,so far i have yet to find it in the inventor dimensioning system.
Regards
Do you mean these?
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Neils
It works fine just one thing why is it not possible to change the tolerance input,as an example when i enter 0.5 it comes in at .5. What i would like is it to read 0.5.
Also the box with the datum ie A,B OR C ETC is less wide than the symbol box,one would expect it to be square.
Any suggestions or is this the inventor default.
Regards
Niels van der Veer
The Netherlands
I believe if you go into your Settings and change the no zero to zero in front you should get your zero in front of your number.
