i have problem with frame generator. I can't insert frame members and it shows me the message in the picture i have uploaded.
I had create a frame and i have reinstall my software(inventor 2013) and now i can t work on it.Before i didn t have this problem.
When you reinstalled the software, did you reload all of the CC Libraries that you had before? Re-establish all of the search paths? Is your Content local or Vault?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Probably i didn't.I reinstall windows and after the inventor.only this. What can i do now?i don t know weither my content is local or vault.where can i see that?
Well, do you use Vault as a company? If so, when it was set up did you or your IT people install the Content Center libraries? If they did, then the place to tell Inventor that you are using Vault Content is in Application Otions on the Content Center tab.
You also need to make sure your Inventor is pointed to the right folder for the Content Center files when you want to use them. Also in Application Options, Files tab: (obviously your path will be different)
Chris Benner
In a brand new assembly, can you insert this component from the CC on its own?
Do you have any connection with the CC?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
I have a student version of inventor from the site of autodesk.i had created a complex frame with over 200 frame members.i had to reinstall windows.
So i reinstall inventor and i had only kept the files of the members (ipt) and the file of the assembly which are at this path
(C:\Program Files\Autodesk\Inventor 2013\Autodesk Inventor 2013\Content\DClibrary\Application Data\Autodesk\Inventor 2013\Content Center\Libraries)
below i upload 2 pictures of tha aplication option that shows to me.
In my desktop there is the icon of Autodesk Vault Basic but i never have used it.
Ok,, you have the student version which indicates that you are limited from the full version on what you can do. Your image indicates that your content center is loaded locally. What I don't understand is why you are reloading windows? And Inventor? This sounds more like an assembly fie issue.
I still have not gotten a response from you in regards to starting a brand new assembly and just inserting this frame piece from the content center to see if it will load. If it does then you know the content center is not the problem.
Check that your CC is being loaded within your Project File. You can select which CC files you wish to load and have access to via your Project File.
https://chronicle.autodesk.com/main/details/4cd5c50f-0e69-4d95-a3a3-6983d2e3cd98
Go to Manage Tab, Editor. open the Cointent Center editor and post a screen shot of that. I suspect that when you reinstalled, you did not reinstall the CC libraries. But the screen shot will tell.
Chris Benner
So it looks like the libraries are there in your installation. I'm leaning now toward Blair's suggestion that they may not be loaded into your project file.
Chris Benner
Thank you for your help but two days now i can't find the solution. i posted the project file.all libraries are checked.
i tried a lot of things and i think that the problem begins from the installation.When i installed the program i had some continious warnings error.
I don t remember exactly what it said. Something about robot structural analysis paths.(path 3,path 4,....).I installed the inventor in a windows desktop machine and i haven t this problem but in my macbook (bootcamp) i cant work with frame generator or frame analysis.
