I'm trying to generate a base assembly using iLogic with frame generator components. The problem I'm running into is that iLogic is not suppressing some of the components. I have 5 frame sizes that either require a 2" square tube frame or a 3" square tube frame. If there is a way to cut down on quiet a bit of the logic it would be greatly appreciated as well.
Attached is the assembly that I'm working in. There should be the iLogic as well as the form for the different sizes.
Sam
Here is a pic of the model we are trying to create. As you can tell from the tree, certian components are suppressed. However, they are not the right ones to be suppressed.
Here is a snippet of the iLogic as well. I captured the current state as they were and everything was working fine till I added some extra components to the assembly. Once I did that I cannot get the frame to adjust.
Also, I created a seperate skeleton to get the two different frames into the assembly.
Any help is greatly appreciated.
I figured it out. I needed to insert a "rebuild" line intot he iLogic for it to work... very weird.
Logic statement:
ThisDoc.Document.Rebuild()
I am playing with the file you uploaded and have also added the Rebuild syntax.
But i still have the same problem. The frame members do not get suppressed while other components get suppressed with the same syntax. I also tired the MakePath syntax
Component.IsActive(MakePath("SubAssem1:1", "Part2:1")) = False
but the frame components do not budge.
Please upload your completed files, or let me know how i can suppress frame generator components.
