In Solid works, you can press the center mouse button down and rotate your view. In Inventor you have to hold shift and the center mouse button for rotation. How do I switch it so the center mouse button will automaticaly switch to rotation without neading shift to be pressed.
Solved by mdavis22569. Go to Solution.
You can search old post ...but most say it's hard coded and stuck that way
http://forums.autodesk.com/t5/Inventor-General/Rotate-Model-with-Middle-Mouse-Button/td-p/3406687
but like this post mention ... what about a spacemouse/spaceball
