Dear all,
I add my worked. this work is a penstock at the hydroelectric powerplant. Due to uneven ground so inclined penstock and have many elbows. in civil engineering drawing section is taken from the axis line. so we compare drawings from the axis of the cross section have to take. what can i do this?
Thanks for all
This is my pipe. As you can see, this pipe has 3d sketch route so i'didn't section to route
I can only think of two possible solutions:
1) Create many sections, each of a portion of the pipeline conforming to a single flat plane.
Or:
2) Create a new copy of the assembly and rotate connections so as to flatten the centerlines to a single flat plane.
