Inventor General
majusmiles
Message 1 of 5 (308 Views)
flattering surfaces
308 Views, 4 Replies
01-03-2013 02:58 PM
Hi
Can i flattern something like You can find on the pic. ( this one is from CATIA ) or something like this. Not everything, just surface by surface. When i draw similar thing, i had problem, because i dont know how to flattern single surface, All of them are curved.
Thank You
blair
Message 2 of 5 (292 Views)
Re: flattering surfaces
01-03-2013 04:04 PM in reply to: majusmiles
You should spend some time on Youtube, and seach for: Inventor, +sheet metal
There are a number of good tutorials that show different features and functionality of the Sheet-Metal module in Inventor.
IV2015 up1 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
majusmiles
Message 3 of 5 (273 Views)
flattering surfaces
01-04-2013 01:11 AM in reply to: blair
Yes, there are a number of good tutorials but i couldn't  find the solution, that's why i am asking, i don't wanto to bend, i wander how can i make templates and than solder them toogether.
JDMather
Message 4 of 5 (256 Views)
01-04-2013 04:25 AM in reply to: majusmiles
A while back (4 or 5 years ago) I posted an example very similar to this.
I will have to search a bit to find it.
It might be better for you to attach your attempt here (modeling the geometry however you can - it doesn't have to be sheet metal).
The solution turns out to be pretty simple.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
majusmiles
Message 5 of 5 (195 Views)
01-05-2013 07:35 AM in reply to: JDMather
ok, i made it, standart.itp.,  sketch( spline), model( extrude(surface option)),circular pattern,  surface(trim,delete), convert to sheet metal, model(surface(thicken offset)), create flat patern, sometimes works strange way, probably i don't understand it enouht, :smileyhappy:
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
