Can we create a flat pattern for part like cup or a tumbler. (Not a sheet metal bend part but a drawn or formed part)
I use inventor 2012.
thank you
Hi Rajeshindi,
a surface can be flattened if the deformation of the base part is only two dimensional. For a part that requires the material to be deformed into three dimensions this is not possible. In cases like this you will have to go with additional software / add-ons like EasyBlank for Inventor.
Regards
Matthias
