Inventor General
Member
d_great_ice
Message 1 of 5 (341 Views)
filtering partlist use filter View
341 Views, 4 Replies
12-25-2012 07:01 PM
Dear Someone,
Can help me, how to filtering a part list use view by assembly drawing, with VBA editor or iLOGic code.
there is no class system in API for filter in partlist class use views filter.
i use autodesk inventor 2010, and get install use ilogic add-ons 2010
i want to get automation system for my inventor design.
Thx.
Ihsan Surahman,
Product Support
VinodBalasubramanian
Message 2 of 5 (297 Views)
Re: filtering partlist use filter View
01-01-2013 10:19 PM in reply to: d_great_ice
You may want to look into the blog article in the below link for sample ilogic codes,
http://forums.autodesk.com/t5/Autodesk-Inventor/iLogic-to-Sort-BOM-Renumber-and-sort-Parts-list/td-p...
Hope it helps.
Vinod Balasubramanian
Member
d_great_ice
Message 3 of 5 (271 Views)
01-04-2013 01:48 AM in reply to: VinodBalasubramanian
link does not exist.
:smileysad:
Please help.
karthur1
Message 4 of 5 (260 Views)
01-04-2013 10:10 AM in reply to: d_great_ice
The URL that he posted was cut off.  I think this might be where he was trying to get you.
Try this....
Curtis_Waguespack
Message 5 of 5 (244 Views)
iLogic partslist filter, parts list filter
01-04-2013 10:45 AM in reply to: d_great_ice
Hi d_great_ice,
I'm not aware of a way to set the parts list filter programatically, but what I've done in the past is to set up a parts list style that has the filter pre-set in that style, and then change the parts list to use that specific style.
I hope this helps.
Curtis
'assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
'Set a reference to the active sheet.
Dim oSheet As Sheet
oSheet = oDrawDoc.ActiveSheet
'set a reference to the first drawing view on the sheet. Assumes it's not a draft view.
Dim oDrawingView As DrawingView
oDrawingView = oSheet.DrawingViews(1)
'define the insert point
Dim oPlacementPoint As Point2d
oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d (27#, 20.625#)
'create the parts list
Dim oPartsList As PartsList
oPartsList = oSheet.PartsLists.Add(oDrawingView, oPlacementPoint)
'set parts list to a specific layer
oPartsList.Layer = oDrawDoc.StylesManager.Layers.Item("Visible (ANSI)")
'set parts list to a specific style
oPartsList.Style = oDrawDoc.StylesManager.PartsListStyles.Item("Material List (ANSI) with Filter")
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
