You can configure the library and tell where it should store the parts.
Any library searchpath is possible. Go to the top level of the library
and pree the configure button, choose the library and edit.
Michael Puschner
mp@scholle.de
"Anders"
schrieb im Newsbeitrag
news:MPG.18613ab428514ab19896ca@discussion.autodesk.com...
> Hi, I notified a difference between IV R5.3 and R6 SP1, when placing
fasteners & steelshapes in
> an assembly. In R5.3 ipt files was generated with a defaultname and placed
in the designated
> library path according to the projectfile. I remember that R5.3 was
looking after the tagname
> "Standardparts" in the ipj-file as below and also only generated the ipt
file if it isn't
> already generated.
> [Library Search Paths]
> Standardparts=D:\Library\standardparts
> If IV R6 doesn't generate fasteners in the designated path with a readible
name as in R5.3,
> there is a great danger for creating dublicated fasteners with different
names.
> Another thing is that I discoverede that ipt-files generated on basis on
the exact same
> fastener isn't binary identical. Some further research revieled the fact
that these 2 parts
> doesn't contain the same FaceID's that mean that one fastener can't be
replaced with the other
> without loosing constraints.
> I can see 2 scenarions where this leads to severe problems:
> 1. If I don't have a backup of fasteners for a project and I need to
generate them again =>
> problem
> 2. Merging two or more projects with duplicates of fasteners. => different
faceId leads to a
> problem.
> I look forward to your comments.
> Regards Anders
