Inventor Forum
file numbering Inventor Proffesional
3 REPLIES 3
isaw
323 Views, 3 Replies
Is it possible to autogenrate a kind of file numbering system? When you make drawings from an assembley, I don't see how the drawings refer to each other? I am looking for a solution, where a drawing number appears in the title block, and is connected with the assembley. Or at least refer to the name of the part.
Isak Wickstrøm
Teacher at CPH-WEST
Vejlebrovej 45
2635 Ishøj
Denmark
A computer....
3 REPLIES 3
stefaanboel
in reply to: isaw
In your Title blocks template from the drawing resources you can add the "Part number" of the model:
If this is the solution, push the solution button Smiley Wink (and maybe some kudos)
LT.Rusty
in reply to: stefaanboel
Chances are very good that the drawing number field on your title block is already tied to the stock number iProperty from your drawing.  If you add a number there, it should show up in your title block, so long as you haven't messed with the templates too much.
Rusty
brendan.henderson
in reply to: isaw
By default the part/assembly iProperty Part Number is the same as the name you use when the file is saved. So in the drawing Title Block you can insert the iProperty <PART NUMBER> which then brings this into the drawing. Also by default the part/assembly and the drawing for that part/assembly are the same, a very easy way to see the link between the part/assembly and the respective drawing.
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
