Inventor General
Active Member
Message 1 of 6 (549 Views)
feature recognition enabler
549 Views, 5 Replies
07-10-2012 05:16 AM
I've upgraded to Inventor 2013, removed 2012 and I want to install Feature Recognition enabler for 2013. It wont install because it says an older version of the add-in exisits. Control Panel won't uninstall it becasure it says Inventor not installed. any thoughts on how to remove the old version of feature recognition?
Cadmanto
Message 2 of 6 (528 Views)
Re: feature recognition enabler
07-10-2012 01:20 PM in reply to: kevin.brown
Kevin,
When you uninstalled 2012 and the feature recognition software did you clean out the registry as well?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17274201&linkID=9242018
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
Active Member
Message 3 of 6 (509 Views)
07-12-2012 05:35 AM in reply to: kevin.brown
No, I simply used the removal tool for design suite 2012
Product Support
Message 4 of 6 (493 Views)
07-12-2012 10:12 AM in reply to: kevin.brown
As the Feature recognition app is not part of the suites, using the quick uninstall on the 2012 suite is rather futile in an attempt to remove the Feature Reconition app.
What I would suggest is to try the Microsoft Fix-it tool, which can be found here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
First choose the Uninstalling option
Then select the Autodesk Feature Recognition Enabler entry to be uninstalled:
Bob
Active Member
Message 5 of 6 (490 Views)
07-12-2012 10:30 AM in reply to: kevin.brown
fix it did the trick! thanks:smileyhappy:
New Member
Message 6 of 6 (387 Views)
10-30-2012 02:45 PM in reply to: bobvdd
Is there any other method you could recommend? The Lab I work at only allows our machines to access the internet through a web portal. The Microsoft Fix-it file tries to "phone home" when executed, but since it can't access the web it fails to run.
I have removed all files relating to the feature recognition enabler and have scoured the registry for any entries related to it. However, it still will not uninstall. In the Windows Uninstall program it shows that there are 3 MB of data stored, but if it's really there you folks have managed to hide it extremely well. I would like to be able to install the 2013 version of this software so I will still be able to import files sent to me, but I am concerned that having the 2012 version still showing up as being installed could wreak havoc with the operating system. If you can suggest a method that does not require it to access the web in order to function it would be greatly appreciated.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
