Two suggestions,
First, try the new "Optimized" pattern option (available in the ">>"
expanded pattern dialog). Position your original cylinder on the plate,
occurrences which don't land on the plate will fail. This gives the result
you want, and as a bonus it's a lot faster. The down side is that you'll
get a warning dialog each time the pattern recomputes, and it will be marked
Sick in the browser because of the failed occurrences. Also, if you center
the cylinder in the plate, I think you'll need four patterns to cover the
whole plate.
The other possibility is to "create the feature at the far left origin, out
in space", then after the pattern, use an Extrude Cut to remove the excess
occurrences. This may not be possible if the part contains other geometry
that would be affected by the cut. It will also leave partial cylinders
where occurrences fall on the boundary of the plate.
You can suppress pattern occurrences as Jeff suggests, though that will be a
bit tedious with such a large pattern.
Tom Sturtevant
Inventor Part Modeling
"elise_moss" wrote in message
news:33065384.1089936744869.JavaMail.jive@jiveforum1.autodesk.com...
> This is a toughie...I have a hexagonal plate (1.2 in sides) and I want to
place a rectangular array of cylinders (.03 in dia, .0745 spacing in the
x-direction, .0645 spacing in the Y-direction). I want to cover the plate
as much as possible.
> If I create the feature at the far left origin, out in space and perform
the array. Obviously some features will be in space. (I tried the adjust
to model option and that didn't suppress those occurrences).
> If I create an array in the center of the hexagon, I am stuck with several
blank spaces which are difficult to array.
> If I was doing this in AutoCAD, it wouldn't be a problem. I could create
the array easily and then just erase the unwanted objects. Of course, I
could do this in Inventor Sketch mode as well, but my understanding is that
this will really eat up memory.
> SolidWorks (sorry, got to invoke a competitor) has a pattern tool that
allows you to select points and place the feature pattern to the
points...this would come in handy in this specific case.
> Other suggestions or ideas are solicited.
> Elise Moss
> www.mossdesigns.com
