Sometimes if you just draw your sketch to the edge of a part it leaves this
cut. If possible extend the sketch past the edge of the part. If you can
post it to CF I'll take a look.
Sean Dotson, PE
http://www.sdotson.com
remove all #s from email
"Mike Grunwald" wrote in message
news:5EFA51338DECAA062502D6C3B39423BC@in.WebX.maYIadrTaRb...
> I have done an extrude, cut, and ended up with a very thin shard of
material
> where there was none before. This seems strange, if I had made a mistake
> with the sketch or the extrude command, you would think it just would not
> have cut enough away? Any one seen this before, work around? I'm afraid
> that if I do an stl file of this, it may be hosed.
> Mike
