Inventor General
Valued Contributor
Mike686
Message 1 of 7 (220 Views)
error inserting frame member
220 Views, 6 Replies
11-12-2012 08:32 AM
hi, i have publish a part to use it with frame generator
when i try to insert it with the frame generator i get the following error message:
"a frame member could not be created. the template file for "MY PART NAME" could not be located in the content center librairy"
i've already publish part and never had this problem different..
the only thing i see i done differently is publish an ipart, usually its just regular part..
but the i re-publish the part as a regular part and i still get the same error message..
can someone help me with that?
Product Design Suite 2013
Cadmanto
Message 2 of 7 (210 Views)
Re: error inserting frame member
11-12-2012 10:32 AM in reply to: Mike686
Hi Mike,
Seeing this is an ipart, did you generate all of the iparts from the factory file before publishing it to the content center?
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
Valued Contributor
Mike686
Message 3 of 7 (199 Views)
11-12-2012 12:55 PM in reply to: Cadmanto
well i'm not sure....
but i deleted the table for the ipart, converting it to a regular part, the save it as another part
then i publish the new part but still had the same error..
it wasnt until i restart the whole process with a new file that the error stop happening
Cadmanto
Message 4 of 7 (190 Views)
11-12-2012 03:46 PM in reply to: Mike686
I am home right now, but I have successfully published iparts to the CC which work fine with the frame generator.
I documented this process and I will in the AM attach it here and you can read through it to see if you did everything I did and possibly see something you missed that is critically needed.  Or maybe you did everything I did and there is a different issue.
I will tell you that the parts I created were not iparts because everything was either controlled through my skeleton part or when inserted through the typed in length.
Best Regards,
Scott McFadden
Cadmanto
Message 5 of 7 (174 Views)
11-13-2012 06:33 AM in reply to: Cadmanto
Here is the document I told you about in my last posting.  Let me know how it works for you.
Best Regards,
Scott McFadden
Cadmanto
Message 6 of 7 (173 Views)
11-13-2012 06:35 AM in reply to: Cadmanto
Here is the second one.  I had to split up my original file because the master is too large for this forum.
When you look at the second one understand that item one is supposed to be 21.  It changed when I split it.
Best Regards,
Scott McFadden
Valued Contributor
Mike686
Message 7 of 7 (118 Views)
11-21-2012 07:38 AM in reply to: Cadmanto
hi scott, thanks a lot for the information
i'm printing what you send me right now
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
