Inventor General
michaelkovacik
Message 1 of 13 (464 Views)
embossing onto multiple surfaces
464 Views, 12 Replies
12-18-2012 01:23 AM
Good Morning Inventor Users
Is there any way of embossing onto
1. Multiple faces
2. surfaces that are not flat, cylindrical or conical
I have tried using the “stitch surface” command but I can’t seem to get it to select .
The surface was created using the loft command, but I don’t know how to select it as a composite surface
When I am doing the emboss.
Maybe it has to be done using another method besides emboss? How?
Any help appreciated
Mike K
*Expert Elite*
Message 2 of 13 (443 Views)
Re: embossing onto multiple surfaces
12-18-2012 05:45 AM in reply to: michaelkovacik
You can only Wrap to cylindrical or conical faces.
Sometimes you need to make the sketch visible agian and apply several embosses - one on each face, but you cannot wrap.
Occasionally you can use Delete Face with Heal to combine two faces into one face.
Attach your file here.
It is hard to tell from your image what you are trying to do.
The Plastic Part - Grill tool might get you what you need even if your part isn't really plastic or the feature isn't really a grill.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
michaelkovacik
Message 3 of 13 (431 Views)
12-18-2012 05:58 AM in reply to: JDMather
See attached
*Expert Elite*
sam_m
Message 4 of 13 (430 Views)
12-18-2012 06:04 AM in reply to: michaelkovacik
There's a few ways to skin the cat:
If that mesh will extrude then it can be easier to offset the relevent outer faces as a surface and extrude the mesh to the offset surface (with the offset distance being the emboss distance) for a cut operation.  For an add opperation you can extrude from the sketch to the part and then use split with the offset surface.
If the mesh is more complex and then extrude as a collection of surfaces and offset the outer faces (as before) and use the sculpt command to do the emboss (either add or subtract).
Please mark this response as "Accept as Solution" if it answers your question...
but please understand that the solution may not be the answer you're wanting to hear...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love :smileyvery-happy:
Lithium - helping nntp users with mania, depression and headaches
*Expert Elite*
Message 5 of 13 (425 Views)
12-18-2012 06:12 AM in reply to: michaelkovacik
Something like this?
see attached
(I very seldom use Emboss)
michaelkovacik
Message 6 of 13 (420 Views)
12-18-2012 06:29 AM in reply to: JDMather
But I can't open your drawing it gives me the following error message.
I am working on Inventor 2013.
Maybe you can just describe what you did, so I can try it out.
I am on my home now.
Will log on again from home.
Mike
PS
do you have a first name?
*Expert Elite*
Message 7 of 13 (414 Views)
12-18-2012 06:35 AM in reply to: michaelkovacik
Offset surface
Extrude TO surface
Jeff
Didn't know whether you wanted to add or cut material.
Simply change offset surface direction and Extrude From-To (Between) the solid and surface if adding material.
Message 8 of 13 (392 Views)
12-18-2012 08:14 AM in reply to: JDMather
Jeff
okay I am at home now. I don't want to open your file, I see it was created on an educational version. I believe that files opened on educational versions corrupt authentic software with the dreaded educational stamp.
I have offset the surface. Now when I try do an extrude between the plane I created the sketch on and the offset sur
face I cannot select the offset surface. It won't select OffsetSrf1 in the browser, and if I try to select the offset surfaces in the model it is extremely difficult to see them, and only slelects one at a time.
Mike
*Expert Elite*
sam_m
Message 9 of 13 (386 Views)
12-18-2012 08:41 AM in reply to: MikeKovacik4928
I'm still on 2012 so can't open your model, but will try to explain...
change the view to show hidden lines, which might make selecting the internally offset surface easier.
if you offset the outer surface as a single quilt instead of offsetting each surface individually it should just be a case of selecting 1 face on the quilt (make sure it is going in the correct direction - might have to change the "alternative solution" in the More tab of the extrusion dialog box).
or extrude the profiles as surfaces and use sculpt to get the same result.
see the attached two examples (made in 2012)
*Expert Elite*
sam_m
Message 10 of 13 (378 Views)
12-18-2012 09:10 AM in reply to: MikeKovacik4928
no need to do the cut between the sketch plane and the offset surface, just do a "to" and then the surface.
also, notice your example picture - the cut direction arrow is pointing up, so suggests you might need to change the direction in the More tab, as I mentioned in the last post.  Here's a picture - check if it works by changing the button here.extrusion1.jpg
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
