I have 2 separate sketches which will be used to EMBOSS on the curved surface.I can get them to work except i want 1 sketch to be Green when Embossed on the surface in color and the other sketch to be red in color when Embossed with the back ground Black.I can only get it to work as 1 color.I tried with Split command but still no luck.After both sketches EMBOSSED to the surface i can only get 1 color for both EMBOSS
Can it be done
Dane
@dane_m_steyne wrote:.....I tried with Split command but still no luck.After both sketches EMBOSSED to the surface i can only get 1 color for both EMBOSS
Dane
My guess is an error in logic. When are you doing the split (you didn't attach a file with Emboss or Split?)
Your first sketch should be only the outside boundary - emboss the entire boundary in one emboss as one color or don't worry about color.
Your second sketch should be only the "zig-zag" to Split the face. Now right click on the two resulting faces and set Properties color as desired.
I suspect your error in logic was the second emboss merges with the first - only one face to color. One face cannot have two colors so you must of course split the face into two faces.
Perhaps you never wanted Emboss at all? Split the cylinder face into 3 faces. (would require 2 Split features)
The CADWhisperer YouTube Channel
Hi
As I was looking for a answer to missing colors in Emboss Patterns, I came around your old problem, and - I know it's old, but I could not stand it - I solve it like this:
1) Your figure must NOT touch each other - I separate them with a small offset - 0,001mm.
2) you have double lines in your figure.(not the problem, but anyway...)
Best regards
DaneLeif
Designer by
Siemens Wind Power
DK-7330 Brande
Denmark
