Inventor General
jeroenwm
Message 1 of 3 (195 Views)
dynamic stress simulation
195 Views, 2 Replies
10-14-2012 08:13 AM
is their a possibility to applay stress like dynamic i have a shaft that has a pully on it , its conectet on an old way
not with a tight fit so it shrinks on it but it works wit a small cut in the shaft where its bolted with just a tiny metal plate.
at this place will be a stress concentration and i wanne see how the noth effect is when their is a dynamic load on it cause if i put a static load on it i know the shaft can handel it but i real life it has broken couple of times so this is what i want to investigate shaft.png
i hope you understand my question and help me  kind regards
Message 2 of 3 (187 Views)
Re: dynamic stress simulation
10-14-2012 10:30 AM in reply to: jeroenwm
Can you test the assembly in the Dynamic Simulation environment and output time-steps to FEA for Motion Loads Analysis?
I don't see any twisting forces on your shaft - how is the shaft used in an assembly?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
jeroenwm
Message 3 of 3 (176 Views)
10-14-2012 12:31 PM in reply to: JDMather
on the shaft is a pully that guides a  chain but somtimes the  chain blocks and so the motor + reductor builds up tention until it releases . i asume that the worst place is when the pully is in that direction when the pulling force is in a perpendicular direction with the flat surface  so the shaft is getting "pulled open" if you get what i mean . i think multiple times of this force will tear the shaft at the red line in the picture. this is how i wanne simulated it
can i do this with inventor or do i need the multi physics for it ?
in other words their isnt going to be a twisting force cause the chain guides trough it only the friction between the chain and pully is going to make it turn around but this forces are neglecteble
Kind regards
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
