Hi All,
I am doing a dynamic simulation in which I have a shaft attached to a gear by some screws, so when the gear rotates the shaft rotates as well. Then when I carry out a dynamic simulation, both the gear and shaft appear as a welded group, but I want to export only the shaft for a FEA. Currently this is not possible because this cannot be done with welded parts (that is the error message I get).
How do I take out the shaft out of the welded group so I can do the FEA?
In this case do not use the Automatic conversion of assembly constraints to DS Joints.
You can retain the Joints already created (when you change the option for automatic conversion), delete the ones you don't want and then manually add the necessary joints to hold the part together (without converting to a Welded Group).
or
Are these parts a sub-assembly?
if so, a bit more work.
(I'm working from memory and might have missed a detail in the steps.) (it could be as simple as Right Mouse Button - Retain DOF)
Can you attach the assembly here?
The CADWhisperer YouTube Channel
Attached is the assembly. How do you remove the automatic conversion?
The propeller,shaft, gears are not a sub-assembly since I thought that by assembling everthing in one file I would have the welded groups problem.
What I want to be able to do is simulate the motor driving the propeller in a dynamic simulation and then export different pieces of the whole set-up to analyze their stresses i.e. the shaft, the gear, or any other part connected to the propeller shaft.
Thanks!
Before moving on to an advanced topic like Dynamic Simulation - you should understand that -
An assembly file (*.iam) is only a list of hyperlinks to the part files (*.ipt) and a record of assembly constraints (and a bit more).
You must include the part files.
I thought so but then maybe it would include the fiels automatically.. here are the files, sorry for that.
You have M5 fasteners going into 6mm blind holes.
I don't think the design will work without an engineering change.
I forgot to change that. I correted that to 5mm holes with m5 threading. But was that change necessary to remove the automatic joint?
@nac69 wrote:
...... I corrected that to 5mm holes with m5 threading. But was that change necessary to remove the automatic joint?
Attach the corrected file here.
The change was not needed for DS, but I never allow my students to progress to DS without mastering the basics.
When I worked in industry out on the shop floor - nearly every project somehow made it out to the shop with basic mistakes like this. It always bothered me that I was resolving the mistakes made by engineers earning twice my pay.
Attach the corrected file.
@nac69 wrote:
The propeller,shaft, gears are not a sub-assembly ...
On opening the assembly I got an error that a sub-assembly was missing?
Hi JDMather,
Sorry I took so long to reply, I went on an internship and had no access to Inventor. Attached is the file with the edited holes. I checked again and there were more holes that were 6mm not 5mm for the M5 screws.
Also before continuing into dynamic simulation, since you mentioned there were more mistakes, if it's not too much work for you could you let me know which are the mistakes so I can fix them? This is all a learning process for me and I want to get it right.
Thanks so much for your help.
Imagine you had this part in one hand and an M5 fastener in the other hand.
You PUSH the M5 fastener into the 5mm hole. What happens? What is the normal behavior of threaded fasteners?
You have made a beginner mistake of using the wrong hole size for a tapped hole - not leaving any material for the threads.
DO NOT use the Thread feature tool for internal threads. Use the Hole feature tool with the Tapped Hole option and Inventor will select the correct Tap Drill size for your threaded fastener specification. This might be the most common mistake I see beginners make (besides not including part files with an assembly).
I will get back to you on the main (DS) problem as my time permits.
The fastener will fall into the hole.
I didn't know that, thanks for the tip. I did this on every hole and now all of them are the right size (I changed to M6 instead). For the unthreaded holes I made them Clearance holes again using the window commands to set the right size for M6 automatically. I attached the new file below for when you get a chance to help me with the D.S.
Meanwhile I will try to make it work too, but at least now the model is better. If you find any more mistakes please let me know to improve it even more (obviously I know you have your own things to do so by what I just said I mean if you just happen to catch one).
Bump!
Just bringing this one back to the top - I keep forgetting to take a closer look.
Edit: Hmmm, maybe that is why - I opened latest attachment and got a unresolved file errors.
Hi JDMather,
do you mean the zip file above made on '08-21-2014 08:16' ? because I attached everything I have.
Also thanks to you and the rest of the Autodesk community answering my questions I am starting to understand more the dynamic simulation (DS) environment. Attached below is a labelled diagram of the 4 parts that I need to design, which I will be referring to from now on.
At this point, if you run the dynamic simulation on the last zip file you'll see it has 3 degrees of mobility:
1 for the pinion
1 for the base #3 in diagram below
1 for a pin in a pin joint which hasn't been constraint correctly, but I don't care about this for now.
From these 3 movable bodies the only one that matters to me is #3(in the diagram below) since I have to design it. This one I should be able to export it into FEA and analyze it because in the ouput grapher I can see the forces involved with this part and the part itself is also a movable body. Now I need to figure out how to carry out FEA on #1,2 & 4.
From what I havelearned so far is that you can't export parts from DS that have no degrees of freedom, grounded or fully constraint into FEA. Now that I think of it maybe parts #1,2 & 4 fall below one of these 3 criteria so that is why I haven't been able to get them to work (i.e. exporting these parts from DS to FEA). So maybe I've been thinking about all of this the wrong way and the way to go about this problem is as follows: from the DS find resultant forces, and then do a static FEA for parts #1,2 & 4 in which I apply these resultant forces and torques. Essentially this is kind of like going around the problem.
What do you think? or maybe I don't have to do a separate static and dynamic analysis to design the 4 parts if I set-up everything correctly?
Edit: added image in the message instead of as attachment
@nac69 wrote:
Hi JDMather,
You have different files in different uploads.
I could combine them and fix everything myself - I understand exactly what you want - but my time is limited.
Perhaps someone else with more time will come and combine the proper assembly without errors and redo the DS Joints.
Note that your latest attachment is missing files from previous attachment.
I am not sure of the two base parts in your image.
These are the component names I see in the assembly browser.
I assume these are the components that you want to analyze?
Since you modeled the motor as one material - is the resulting mass approximately correct? (you can override it if not)
What is the mass of the beam?
Ok so now all the files should be there, I saved everything using 'pack and go', the main assembly is 'assembly 2'.
In DS I just added a belt joint between the pinion and the gear and impossed a motion on the pinion, so if you try to run the DS you will see things moving the right way.
I DID IT!! I changed the constraints in assembly mode and that fixed things, look! :
I know it doesn't look nice though. When opening DS (prior to performing FEA) there was a warning that the model was overconstrained, but at least I got something! and the numbers look ok too! I'm so excited I finaly made some good progress. However the next part is tricky because I'm not sure on how to fix the overconstrained issue:
The problem seems to be on how I constrained the 3 M6 fasteners between the propeller welded group (prop, shaft, gear) and the back base plate. attached is only the assembly file, all the parts are in the zip file above called 'complete system'.
I used align and insert and that seems to have thrown off the DS but I have no idea why, any clue?
