I need urgent help please. I did raise this issue earlier but would like to talk about that again.
In a multibody part file, creating a sketch is easy. I hide all other multibodies and work with only 1 solid body. I can create a sketch and work as shown without having all other multibodies visible.
But, the problem starts if I want to edit that sketch later. When I select the sketch and go for editing, this how the screen looks. Though visibility is off, all the parts are visible and hiding the sketch I want to work with.
any help?
Will hitting the F7 key still slice the graphics?
Wasn't this covered earlier.
The parents of children on shown.
Use the origin planes and centerpoint if possible rather than projected sketch or especially projected feature geometry.
http://forums.autodesk.com/t5/Autodesk-Inventor/editing-sketch/m-p/3438935#M433311
What you are seeing is normal and logical behavior.
Using the BORN technique will eliminate this problem.
http://home.pct.edu/~jmather/skillsusa%20university.pdf
Hi Rajesh,
This is being currently investigated by our development team. I will keep you posted on the updates.
In cases like this I switch to wire frame so I can see what's happening.
