Inventor General
Distinguished Contributor
rajeshindi
Message 1 of 8 (344 Views)
driving me crazy
344 Views, 7 Replies
05-24-2012 01:12 AM
I need urgent help please.  I did raise this issue earlier but would like to talk about that again.
In a multibody part file, creating a sketch is easy.  I hide all other multibodies and work with only 1 solid body.  I can create a sketch and work as shown without having all other multibodies visible.
         But, the problem starts if I want to edit that sketch later.  When I select the sketch and go for editing, this how the screen looks.  Though visibility is off, all the parts are visible and hiding the sketch I want to work with.
any help?
Valued Mentor
RayFeiler
Message 2 of 8 (317 Views)
Re: driving me crazy
05-24-2012 05:11 AM in reply to: rajeshindi
Will hitting the F7 key still slice the graphics?
Product Design Suite Ultimate 2014 64-Bit
Sometimes you just need a good old reboot.
JDMather
Message 3 of 8 (314 Views)
05-24-2012 05:15 AM in reply to: rajeshindi
Wasn't this covered earlier.
The parents of children on shown.
Use the origin planes and centerpoint if possible rather than projected sketch or especially projected feature geometry.
http://forums.autodesk.com/t5/Autodesk-Inventor/editing-sketch/m-p/3438935#M433311
What you are seeing is normal and logical behavior.
Using the BORN technique will eliminate this problem.
http://home.pct.edu/~jmather/skillsusa%20university.pdf
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
rajeshindi
Message 4 of 8 (264 Views)
05-24-2012 01:11 PM in reply to: rajeshindi
No, it doesn't slice the graphics.
rajeshindi
Message 5 of 8 (261 Views)
05-24-2012 01:17 PM in reply to: rajeshindi
I thought there may a simple option of choosing don't want to see parents while editing sketch.
I read thru ur BORN tech. I will try to work around that here after. In saying that is there any way to create a plane say 50 mm offset to a existing part surface and delete the associvity between them. In other words, can we create non associative work features. I use inv 2013.
Product Support
VinodBalasubramanian
Message 6 of 8 (171 Views)
06-24-2012 08:02 PM in reply to: rajeshindi
Hi Rajesh,
This is being currently investigated by our development team. I will keep you posted on the updates.
Vinod Balasubramanian
rajeshindi
Message 7 of 8 (169 Views)
06-24-2012 08:12 PM in reply to: VinodBalasubramanian
Hi Vinod,
Thanks and appreciated.  Interested to see the fix ASAP.
Valued Mentor
stevec781
Message 8 of 8 (135 Views)
06-25-2012 10:15 AM in reply to: rajeshindi
In cases like this I switch to wire frame so I can see what's happening.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
