Inventor Forum
drive bevel gear
4 REPLIES 4
lis_wang
306 Views, 4 Replies
drive bevel gear
I want to animate the bevel gear in the assembly.
When I drived the constrain "DRIVE" in frame_SVOG.ipt, the part shaft_SVOG.ipt did not turn with the part pinion_SVOG.ipt. However if I unsupress the constrain "Mate: 9" in Key connection:1, the part shaft_SVOG.ipt can turn wth pinion_SVOG,ipt, but the part wheel_SVOG.ipt cannot turn with pinion_SVOG,ipt.
I attached the file here. As the file size is big so I broke down into 2 files. Please help me to solve the problem.
4 REPLIES 4
JDMather
in reply to: lis_wang
Did you roll up the EOPs?
Find the red End of Part marker in the browser.
(End of Folded on sheet metal parts EOF)
Drag the red EOP to the top of the browser hiding all features.
Save the file with the EOP in a rolled up state.
Right click on the file name and select Send to Compressed (zipped) Folder.
Attach the resulting *.zip file here.
rdyson
There's probably better ways but one is to delete the DAcc assembly and just place the individual pinion and wheel in your assembly and do a motion constraint.
PDSU 2016
lis_wang
in reply to: rdyson
If I did that way, then I have to manually place pinion and wheel to avoid interferance between them.
lis_wang
in reply to: JDMather
I tried, but only reduce a bit memory and in  the assembly, all the constrains have problem. So i did not do drag the EOP.
