I am trying to put an angular dimension from a hole to a slot positioned planes 90degrees to each other. How can I achieve this? Typically, it depends on how it is put into the ipt file but I didn't know how else to put the slot in therefore only a point was put in at that angle.
Solved by JDMather. Go to Solution.
If I understand the problem - you could add a Centerline Bisector and then dimension the angle to that.
simply select the two hidden line edges of the slot to indicate the centerline angle of the slot.
