Inventor General
Distinguished Contributor
JimSteinmeyer
Message 11 of 16 (386 Views)
Re: dimensioning slots
03-28-2012 09:59 AM in reply to: JDMather
JD,
Interesting, I was finally able to get the glyph to show  but it only gives me the dimension of the segment between the arcs. maybe the difference is due to my having  arcs and not circles. I will keep playing with it and will probably get it to work with practice.
Thank you for your help.
Jim
Jim
Inventor Premium 2013 SP1.1
Vault 2013- plain vanilla version
HP G71 notebook
celeron cpu w\ 4gb RAM and 64 bit system
Win 7 home premium
Ya, my boss has me running my personal machine at work.
JimSteinmeyer
Message 12 of 16 (383 Views)
03-28-2012 10:02 AM in reply to: JDMather
JD,
It does look like the symetry command will be my friend from now on.
Thank you
Jim
HP G71 notebook
Win 7 home premium
Valued Mentor
Rich.O.3d
Message 13 of 16 (343 Views)
03-29-2012 06:48 PM in reply to: jtylerbc
jtylerbc wrote:
...that you can't insert parameters in the text of a dimension,...
hmmm...
On the edit dimension box, there is a button with a pencil on it.
If you click that, then you go to the text editor box.
In the text editor box, you can pick the part and the paramater that you want to show in the dimension.
You may be confusing with iproperties, which you cant pick for dims.
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
jtylerbc
Message 14 of 16 (331 Views)
03-30-2012 05:27 AM in reply to: JimSteinmeyer
You're right - my mistake.  Not sure how I was missing that, since I use it all the time in view labels.  Thanks.
So, Jim,  you can follow my previously posted method in a radial dimension, if you click the pencil icon first to get to the full text editor.  Doing it that way, you'll only have to insert the parameter for the length, instead of both radius and length.  Should take some of the pain out of it.
John Tyler
Inventor 2013
Windows 7 64 Bit
JimSteinmeyer
Message 15 of 16 (313 Views)
04-02-2012 06:16 AM in reply to: jtylerbc
Thank you. It seems a long way around the barn to get something done, but at least we can do it.
Jim
Jim
HP G71 notebook
Win 7 home premium
Valued Mentor
Rich.O.3d
Message 16 of 16 (292 Views)
04-02-2012 05:28 PM in reply to: JimSteinmeyer
this functionality should be added into the hole note tool
after all slots are considered to be elongated holes
I set the dimension names to slot_width and slot_length (refer attached) as I create them.
This makes it easier to find them when you create your leader note or dimensions.
CAD Management 101:
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
