Is there any way to dimension my features, whether it's a sketch or using the hole feature, to either the middle of my part or to a middle plane I have?
I am wanting a group of tapped holes to be the same from the middle of my part, regardless of what the overall size of the part is.
How can I dimension like this?
Thank you for your help.
Solved by mrattray. Go to Solution.
Yes, there are several ways to do this.
If the part has symmetry then model symmetrical about the Origin Center Point and use that as your datum (or project the workplane.
Perhaps it would be best if you posted an example file of your work.
The part will not have symmetry. There wil be a notch in one side, again dimensioned from the middle.
I will have 12 tapped holes, 6 each side of the middle, but I will have different sized plates.
File attached. You should be using the origin geometery to reflect the obvious symmetery of the part whenever possible. I'm sure JD will post his white paper on the how's and why's of this. It's well worth a read.
@Anonymous wrote:The part will not have symmetry......
Sounds like symmetry to me. My definition of symmetry is not that the entire part is symmetrical, but that significant features can be modeled/controlled about some obvious symmetry.
You should have posted finished part any way that you could do it for suggestions on improved techniques, anyone can make a rectangular face.
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
