Inventor General
New Member
carey.olson
Message 1 of 3 (473 Views)
dimension from quadrant of circle to appt intersection on a cirlce
473 Views, 2 Replies
01-10-2013 12:34 PM
*Expert Elite*
Cadmanto
Message 2 of 3 (465 Views)
Re: dimension from quadrant of circle to appt intersection on a cirlce
01-10-2013 12:56 PM in reply to: carey.olson
Carey,
Welcome to the forum.
Take a look at this link.  See if it helps you.
http://forums.autodesk.com/t5/Autodesk-Inventor/Tangent-Dimensioning-of-Arcs/td-p/3317169
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
*Pro
sbixler
Message 3 of 3 (430 Views)
01-11-2013 04:40 AM in reply to: carey.olson
My solution below is in Inventor 2013, but since you didn't tell us what version you're using, I don't know if you can open it.
This isn't as easy as it ought to be, but here's how I did it (see attached).  I created a view sketch, projected the two arcs, and created an arc concentric with the big "circle" as an extension to show the complete circle (set to the Dimension layer).  I then put in a Sketch-Only line between the arc centers, then a normal line tanget to the sketched arc and perpendicular to the previous line.  This last line is purely for something to dimension to.  I exited the sketch, then created a dimension between the tangent line just placed and the quadrant of the small arc.  Then I went back into the sketch and changed that tangent line to Sketch Only so it is not visible.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
