Inventor Forum
dimension color
2 REPLIES 2
134 Views, 2 Replies
dimension color
Is there a trick to controlling a dimension's color in drawing mode? I can
easily change the color of visible lines, but the dimensions don't seem to
follow the same path.
Stephen R.
2 REPLIES 2
Never mind that question, I should have known better.
Dimension styles.
Stephen R.
"stephen r" wrote in message
news:36FC2062481AB2B62C6B1E63D72A7D8F@in.WebX.maYIadrTaRb...
can
> Stephen R.
Format >> Dimension Styles >> Display tab you can change the dimension line color
Format >> TextStyles>> Select the style name that the Dimstyle uses and to the right of
the justification buttons is a button to change color
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
> Stephen R.
