Inventor General
Active Member
oldfahrt
Message 1 of 4 (266 Views)
Accepted Solution
dimension alignment "on the fly"
266 Views, 3 Replies
11-20-2013 01:45 PM
One thing drives me crazy, because I just don't remember how to set it up in AutoCAD Mechanical 2013. Here it is: one single separate dimension is already on the drawing, later I want to put another single dimension somewhere else in the same direction and align it's position with previous one using snap on to text position feature. I know there's dimension alignment tool to do such thing after the fact, but how to do it during the placement of dimension?
*Expert Elite*
cwhetten
Message 2 of 4 (256 Views)
Re: dimension alignment "on the fly"
11-20-2013 02:05 PM in reply to: oldfahrt
You mention AutoCAD Mechanical 2013.  This is the Inventor forum.  Is your question about Inventor, or did you mean to post your question in the AutoCAD forum?
Cameron Whetten
Inventor 2014
*Expert Elite*
Cadmanto
Message 3 of 4 (238 Views)
11-20-2013 06:25 PM in reply to: oldfahrt
If y chance you are talking about aligning these dimensions in Inventor, just ctrl tag both of them and then RC and select "Align Dimension".
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! :smileyvery-happy:
Best Regards,
Scott McFadden
Inventor Professional 2013
(Colossians 3:23-25)
Active Member
oldfahrt
Message 4 of 4 (219 Views)
11-20-2013 11:46 PM in reply to: cwhetten
I'm sorry, indeed this is not Inventor's issue.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
