Inventor Forum
different BOM reference structure in same .IAM possible??
4 REPLIES 4
VIROrene
361 Views, 4 Replies
Let's say i want to draw a bike. In the 2D IDW of the wheel I want to see the frame as a reference. So, in the .iam of the wheel the frame subassembly is inserted and checked as reference. Also, a new level of detail is created that surpressed the frame.This level of detail is used in the overall assemby of the bike.
So, I end up with several subassembly's that contain other subassembly's just to reference them in the IDW. It would be better to have just one master assemby and create several IDW's from that assembly with different LOD and reference settings.
What is your approach?
Rene
Inventor 2012 - 64 bit - build190 - Windows 7
4 REPLIES 4
Hi VIROrene,
I think what I would do is use a Postional Representation in combination with View Repersentations at the top level assembly. And place an overlay view in the drawing.
  • Create the View Rep for the wheel with everything else suppressed (you can copy your existing LOD to a view rep by right clicking the LOD and choosing Copy to View Rep).
  • Create a Pos Rep called Wheel also (but don't create any constraint overrides as you normally would for a pos rep).
  • Create the LOD for the frame with everything else suppressed.
  • In the drawing, place a view of the wheel view rep.
  • Then use the Overlay View tool to place a view of the Frame view rep (using the posistional rep) on top of the wheel view, and choose the Layer option: As Overlay.
I hope this helps.
Curtis
mcgyvr
in reply to: Curtis_Waguespack
What's the point in referencing a bike frame in a drawing to make a wheel? The wheel should be able to be constructed without any knowledge of the frame. You are just making life harder for yourself.
Thank you. This is a good trick; I am gonna try it. Not quite sure if the BOM structure goed right for each LOD and overall LOD. Will see...
Rene
VIROrene
in reply to: mcgyvr
mcgyvr wrote: You are just making life harder for yourself.
Haha, tell it to my customer please!
