I occasionally create a skeleton, and derive seperate sheet metal parts from different sides of it due to sheet size availability. For some reason IV 2013 keeps changing the thickness of the parts to be the same as the skeleton, even though some of the items need to be different a thickness one to another. Frustarting to say the least.
Especially happens when the "skeleton" is actually just another sheet metal part itself. Works only if using manual type in on the Thickness parameter. I am also using SPI , for bend parameters, so n0ot sure if that affects it, and if so, how to get thousands of parts not to break if I need to cut SPI loose.
Ugh, Thanks for listening, Thad
